Speedy Q-learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Speedy Q-learning
We introduce a new convergent variant of Q-learning, called speedy Q-learning, to address the problem of slow convergence in the standard form of the Q-learning algorithm. We prove a PAC bound on the performance of SQL, which shows that for an MDP with n state-action pairs and the discount factor γ only T = O(log(n)/(ε^2 (1 - γ)^4)) steps are required for the SQL algorithm to converge to an ε-optimal action-value function with high probability. This bound has a better dependency on 1/ε and 1/(1 - γ), and thus, is tighter than the best available result for Q-learning. Our bound is also superior to the existing results for both model-free and model-based instances of batch Q-value iteration that are considered to be more efficient than the incremental methods like Q-learning.
speedy-QL_nips2011.pdf (122.14 Ko) Télécharger le fichier
hal-00830140 , version 1 (04-06-2013)
  • HAL Id : hal-00830140 , version 1
Mohammad Gheshlaghi Azar, Rémi Munos, Mohammad Ghavamzadeh, Hilbert Kappen. Speedy Q-learning. Advances in Neural Information Processing Systems, 2011, Spain. ⟨hal-00830140⟩
934 Consultations
795 Téléchargements
