Robust tree-structured named entities recognition from speech - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christian Raymond
Named Entity Recognition (NER) is a well-known Natural Language Processing (NLP) task, used as a preliminary processing to provide a semantic level to more complex tasks. Recently a new set of named entities has been defined, this set has a multilevel tree structure, where base entities are combined to define more complex ones. In this paper I describe, an effective and original NER system robust to noisy speech inputs that ranked first at the 2012 ETAP NER evaluation campaign with results far better than those of the other participating systems.
icassp2013.pdf (509.99 Ko) Télécharger le fichier
poster.pdf (510.45 Ko) Télécharger le fichier
Format : Autre
hal-00830142 , version 1 (04-06-2013)
  • HAL Id : hal-00830142 , version 1
Christian Raymond. Robust tree-structured named entities recognition from speech. Proceedings of the International Conference on Acoustic Speech and Signal Processing, May 2013, Vancouver, Canada. ⟨hal-00830142⟩
226 Consultations
616 Téléchargements
