Comments on actuator fault accommodation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The present work concerns the problem of progressive accommodation to actuator failure. An optimal nonlinear controller synthesis approach is formulated on the basis of the closed loop stability objective. The authors show the interest of the proposed method even for a local analysis when a linear approximation is used. This work focuses on a solution to ensure stability while accommodating to actuator failure. The approach is illustrated in an academic example.
vfsp09.pdf (139.2 Ko) Télécharger le fichier
hal-00830185 , version 1 (04-06-2013)
  • HAL Id : hal-00830185 , version 1
Thibaut Raharijaona, Rachid Outbib, Mustapha Ouladsine, Ghachem Sahbi. Comments on actuator fault accommodation. Safeprocess, Jun 2009, Barcelona, Spain. ⟨hal-00830185⟩
171 Consultations
173 Téléchargements
