L-Py, an open L-systems framework in Python - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
L-systems were conceived as a mathematical framework for modeling growth of plants. In this paper, we present L-Py, a simulation software that mixes L-systems construction with the Python high-level modeling language. In addition to this software module, an integrated visual development environment has been developed that facilitates the creation of plant models. In particular, easy to use optimization tools have been integrated. Thanks to Python and its modular approach, this framework makes it possible to integrate a variety of tools defined in different modeling context, in particular tools from the OpenAlea platform. Additionally, it can be integrated as a simple growth simulation module into more complex computational pipelines.
boudon-fspm.pdf (364.89 Ko) Télécharger le fichier
Format : Figure, Image
hal-00831780 , version 1 (07-06-2013)
  • HAL Id : hal-00831780 , version 1
Frédéric Boudon, Thomas Cokelaer, Christophe Pradal, Christophe Godin. L-Py, an open L-systems framework in Python. 6th International Workshop on Functional-Structural Plant Models, 2010, Davis, CA, United States. pp.116-119. ⟨hal-00831780⟩
829 Consultations
1182 Téléchargements
