Limit cycles in piecewise-affine gene network models with multiple interaction loops
In this article, we consider piecewise affine differential equations modelling gene networks. We work with arbitrary decay rates, and under a local hypothesis expressed as an alignment condition of successive focal points. The interaction graph of the system may be rather complex (multiple intricate loops of any sign, multiple thresholds, etc.). Our main result is an alternative theorem showing that if a sequence of region is periodically visited by trajectories, then under our hypotheses, there exists either a unique stable periodic solution, or the origin attracts all trajectories in this sequence of regions. This result extends greatly our previous work on a single negative feedback loop. We give several examples and simulations illustrating different cases. A preprint version is available as INRIA research report RR-6875 http://www-sop.inria.fr/virtualplants/Publications/2009/FG09/.
RR-6875.pdf (315.46 Ko)
Télécharger le fichier
Format : Figure, Image
