Phase change-related variations of dome shape in Eucalyptus urophylla x Eucalyptus grandis shoot apical meristems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Trees - Structure and Function Année : 2010
Shoot apical meristem (SAM) domes derived from five different outdoor and in vitro sources of juvenile and mature Eucalyptus urophylla x Eucalyptus grandis akin genotypes were compared. Overall measurements of SAM dome height H and diameter D ranged from 2 to 35 µm and 20 to 80 µm, notwithstanding significant differences according to the various physiological origins of plant material investigated. SAM domes from the mature trees ?Mat? were taller than those from the rejuvenated ministock plants ?Rej?; from the in vitro microcuttings ?IVM? of the same clone, and also from the in vitro juvenile seedlings ?IVJ?, whereas outdoor seedlings ?Juv? SAM domes exhibited intermediate height. SAM domes from the rejuvenated material ?Rej?, from the in vitro mature ?IVM? and juvenile ?IVJ? origins were also narrower than those from the outdoor seedlings ?Juv? and to lesser extent than those from the mature trees ?Mat?. Overall the mature source ?Mat? displayed bigger and somehow sharper hemispherical domes than those from ?Rej? and ?Juv?, physiologically more juvenile, or those from the in vitro origins ?IVM ? and ?IVJ? which looked flatter and smaller. SAM dome height, diameter D and H/D values varied also significantly according to shoot apex status. More specifically, H, D and H/D SAM differences between the five origins were not significant when SAM were in their more organogenic stage, to become more salient as leaf structures started to elongate and to differentiate. This was particularly obvious for mature tree ?Mat? SAM dome shapes which showed at this stage much higher H/D values than the other SAM sources. Additionally, a shape index S used for characterizing more accurately dome shape confirmed these trends. These observations provide additional arguments to the view that juvenility in trees become more and more time and space restricted as ageing increases in the course of time during the ontogenetical process, to be ultimately confined to the more organogenic phases of SAM, from which shoot characteristics derive.
MankessiiProfilsPicturefreeRev5.pdf (489.26 Ko) Télécharger le fichier
Format : Figure, Image
hal-00831788 , version 1 (07-06-2013)
François Mankessi, Aubin-R. Saya, Frédéric Boudon, Yann Guédon, Fabienne Montes, et al.. Phase change-related variations of dome shape in Eucalyptus urophylla x Eucalyptus grandis shoot apical meristems. Trees - Structure and Function, 2010, 24 (4), pp.743-752. ⟨10.1007/s00468-010-0444-7⟩. ⟨hal-00831788⟩
211 Consultations
891 Téléchargements
