ParadisEO-MO: From Fitness Landscape Analysis to Efficient Local Search Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Heuristics Année : 2013
This paper presents a general-purpose software framework dedicated to the design, the analysis and the implementation of local search metaheuristics: ParadisEO-MO. A substantial number of single solution-based local search metaheuristics has been proposed so far, and an attempt of unifying existing approaches is here presented. Based on a fine-grained decomposition, a conceptual model is proposed and is validated by regarding a number of state-of-the-art methodologies as simple variants of the same structure. This model is then incorporated into the ParadisEO-MO software framework. This framework has proven its efficiency and high flexibility by enabling the resolution of many academic and real-world optimization problems from science and industry.
humeau_joh2013.pdf (310.84 Ko) Télécharger le fichier
hal-00832029 , version 1 (02-03-2023)
Jérémie Humeau, Arnaud Liefooghe, El-Ghazali Talbi, Sébastien Verel. ParadisEO-MO: From Fitness Landscape Analysis to Efficient Local Search Algorithms. Journal of Heuristics, 2013, 19 (6), pp.881-915. ⟨10.1007/s10732-013-9228-8⟩. ⟨hal-00832029⟩
613 Consultations
45 Téléchargements
