A New Measure of Watermarking Security: The Effective Key Length - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Forensics and Security Année : 2013
Patrick Bas
Connectez-vous pour contacter l'auteur
Teddy Furon
Whereas the embedding distortion, the payload and the robustness of digital watermarking schemes are well understood, the notion of security is still not completely well defined. The approach proposed in the last five years is too theoretical and solely considers the embedding process, which is half of the watermarking scheme. This paper proposes a new measure of watermarking security, called the effective key length, which captures the difficulty for the adversary to get access to the watermarking channel. This new methodology is applied here to additive spread spectrum schemes where theoretical and practical computations of the effective key length are proposed. Experimental protocols using either Monte-Carlo simulations, region approximation or rare event probability estimator allow good evaluation of this quantity. For Improved Spread Spectrum (ISS), our analysis exhibits setups where i) the robustness and the security of the scheme are superior to Spread Spectrum and ii) estimating the secret keys from the observations only is not the best way to break the scheme. Moreover a comparison with Correlation Aware Spread Spectrum (CASS) shows that ISS offers a better security than CASS for a given robustness.
papierTIFSKeyLength_FinalHAL.pdf (1.31 Mo) Télécharger le fichier
hal-00836404 , version 1 (20-06-2013)
  • HAL Id : hal-00836404 , version 1
Patrick Bas, Teddy Furon. A New Measure of Watermarking Security: The Effective Key Length. IEEE Transactions on Information Forensics and Security, 2013, 8 (8), pp.1306 - 1317. ⟨hal-00836404⟩
421 Consultations
632 Téléchargements
