On the Geometrical Gyro-Kinetic Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2014
Considering a Hamiltonian Dynamical System describing the motion of charged particle in a Tokamak or a Stellarator, we build a change of coordinates to reduce its dimension. This change of coordinates is in fact an intricate succession of mappings that are built using Hyperbolic Partial Differential Equations, Differential Geometry, Hamiltonian Dynamical System Theory and Symplectic Geometry, Lie Transforms and a new tool which is here introduced : Partial Lie Sums.
Frenod_Lutz.pdf (529.26 Ko) Télécharger le fichier
hal-00837591 , version 1 (23-06-2013)
hal-00837591 , version 2 (17-07-2013)
hal-00837591 , version 3 (13-07-2014)
Emmanuel Frénod, Mathieu Lutz. On the Geometrical Gyro-Kinetic Theory. Kinetic and Related Models , 2014, 7 (4), pp.621-659. ⟨10.3934/krm.2014.7.621⟩. ⟨hal-00837591v3⟩
651 Consultations
299 Téléchargements
