Evaluation of Real-Time Audio-to-Score Alignment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This article explains evaluation methods for real-time au- dio to score alignment, or score following, that allow for the quantitative assessment of the robustness and precise- ness of an algorithm. The published ground truth data base and the evaluation framework, including file formats for the score and the reference alignments, are presented. The work, started for MIREX 2006, is meant as a first step towards a standardized evaluation process contributing to the exchange and progress in this field.
Cont07_ScofoEvaluation.pdf (60.04 Ko) Télécharger le fichier
hal-00839068 , version 1 (27-06-2013)
  • HAL Id : hal-00839068 , version 1
Arshia Cont, Diemo Schwarz, Norbert Schnell, Christopher Raphael. Evaluation of Real-Time Audio-to-Score Alignment. International Symposium on Music Information Retrieval (ISMIR), 2007, Vienna, Austria. ⟨hal-00839068⟩
441 Consultations
957 Téléchargements
