Realtime Multiple-pitch and Multiple-instrument Recognition For Music Signals using Sparse Non-negative Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper we introduce a simple and fast method for realtime recognition of multiple-pitches produced by multiple musical instruments. Our proposed method is based on two important facts: one that timbral information of any instrument is pitch-dependant and two, that the modulation spectrum of the same pitch seems to result into a persistent representation of the characteristics of the instrumental family, as discussed in the paper. Using these basic facts, we construct a learning algorithm to obtain pitch templates of all possible notes on various instruments and then devise an online algorithm to decompose a realtime audio buffer using the learned templates. The learning and decomposition proposed here are inspired by non-negative matrix factorization methods but differ by introduction of an explicit sparsity control. Our test results show significant recognition rate for a realtime system and on real music recordings. We discuss further improvements that can be made over the proposed system.
Mots clés
NMF
ArshiaCont_dafx07.pdf (355.12 Ko) Télécharger le fichier
hal-00839069 , version 1 (27-06-2013)
  • HAL Id : hal-00839069 , version 1
Arshia Cont, Shlomo Dubnov, David Wessel. Realtime Multiple-pitch and Multiple-instrument Recognition For Music Signals using Sparse Non-negative Constraints. Proceedings of Digital Audio Effects Conference (DAFx), 2007, Bordeaux, France. ⟨hal-00839069⟩
403 Consultations
510 Téléchargements
