Robust image-based visual servoing using invariant visual information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Robotics and Autonomous Systems Année : 2013
This paper deals with the use of invariant visual features for visual ser- voing. New features are proposed to control the 6 degrees of freedom of a robotic system with better linearizing properties and robustness to noise than the state of the art in image-based visual servoing. We show in this paper that by using these features the behavior of image-based visual servoing in task space can be significantly improved. Several experimental results are provided and validate our proposal.
2013_ras_tahri.pdf (2.16 Mo) Télécharger le fichier
hal-00840266 , version 1 (02-07-2013)
Omar Tahri, Helder Araujo,, François Chaumette, Youcef Mezouar. Robust image-based visual servoing using invariant visual information. Robotics and Autonomous Systems, 2013, 61 (12), pp.1588-1600. ⟨10.1016/j.robot.2013.06.010⟩. ⟨hal-00840266⟩
354 Consultations
400 Téléchargements
