A simple second-order cartesian scheme for compressible flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A simple second order scheme for compressible inviscid flows on cartesian meshes is presented. An appropriate Rieman solver is used to impose the impermeability condition. The level set function defines the immersed body and provides some useful geometrical data to increase the scheme accuracy. A modification of the convective fluxes computation for the cells near the solid ensures the boundary condition at second order accuracy. The same procedure is performed in each direction independently. An application to the simulation of a Ringleb flow is presented to demonstrate the accuracy of the method.
FVCA6_033.pdf (175.68 Ko) Télécharger le fichier
hal-00840339 , version 1 (02-07-2013)
  • HAL Id : hal-00840339 , version 1
Yannick Gorsse, Angelo Iollo, Lisl Weynans. A simple second-order cartesian scheme for compressible flows. Finite Volumes for Complex Applications VI, Jaroslav Fořt, Jiří Fürst, and Jan Halama, Jun 2011, Prag, Czech Republic. ⟨hal-00840339⟩
327 Consultations
286 Téléchargements
