Rankcluster: An R package for clustering multivariate partial rankings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The R Journal Année : 2014
Rankcluster is the first R package dedicated to ranking data. This package proposes modelling and clustering tools for ranking data, potentially multivariate and partial. Ranking data are modelled by the Insertion Sorting Rank (isr) model, which is a meaningful model parametrized by a central ranking and a dispersion parameter. A conditional independence assumption allows to take into account multivariate rankings, and clustering is performed by the mean of mixtures of multivariate isr model. The clusters parameters (central rankings and dispersion parameters) help the practitioners in the interpretation of the clustering. Moreover, the Rankcluster package provides an estimation of the missing ranking positions when rankings are partial. After an overview of the mixture of multivariate isr model, the Rankcluster package is described and its use is illustrated through two real datasets analysis.
Rankcluster.pdf (177.28 Ko) Télécharger le fichier
hal-00840692 , version 1 (02-07-2013)
hal-00840692 , version 2 (20-08-2013)
hal-00840692 , version 3 (27-02-2014)
Julien Jacques, Quentin Grimonprez, Christophe Biernacki. Rankcluster: An R package for clustering multivariate partial rankings. The R Journal, 2014, 6 (1), pp.10. ⟨10.32614/rj-2014-010⟩. ⟨hal-00840692v3⟩
502 Consultations
1251 Téléchargements
