Letter-to-phoneme conversion by inference of rewriting rules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Phonetization is a crucial step for oral document processing. In this paper, a new letter-to-phoneme conversion approach is pro- posed; it is automatic, simple, portable and efficient. It relies on a machine learning technique initially developed for translit- eration and translation; the system infers rewriting rules from examples of words with their phonetic representations. This approach is evaluated in the framework of the Pronalsyl Pas- cal challenge, which includes several datasets on different lan- guages. The obtained results equal or outperform those of the best known systems. Moreover, thanks to the simplicity of our technique, the inference time of our approach is much lower than those of the best performing state-of-the-art systems. Index Terms : phonetization, inference of rewriting rules, phonemization, grapheme-to-phoneme, Pronalsyl Challenge.
Claveau-IS09-vf.pdf (92.55 Ko) Télécharger le fichier
hal-00844000 , version 1 (12-07-2013)
  • HAL Id : hal-00844000 , version 1
Vincent Claveau. Letter-to-phoneme conversion by inference of rewriting rules. Interspeech, ISCA, Sep 2009, Brighton, United Kingdom. pp.1299-1302. ⟨hal-00844000⟩
143 Consultations
178 Téléchargements
