On Interval Observer Design for a Class of Continuous-Time LPV Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work is devoted to interval observer design for Linear Parameter-Varying (LPV) systems under assumption that the vector of scheduling parameters is not available for measurements. Stability conditions are expressed in terms of matrix inequalities, which can be solved using standard numerical solvers. Robustness and estimation accuracy with respect to model uncertainty is analyzed using L_inf/L_1 framework. Two solutions are proposed for nonnegative systems and for a generic case. The efficiency of the proposed approach is demonstrated through computer simulations.
Automatique
NOLCOS2.pdf (235.2 Ko) Télécharger le fichier
hal-00844390 , version 1 (15-07-2013)
  • HAL Id : hal-00844390 , version 1
Stanislav Chebotarev, Denis Efimov, Tarek Raissi, Ali Zolghadri. On Interval Observer Design for a Class of Continuous-Time LPV Systems. IFAC Nolcos 2013, Sep 2013, Toulouse, France. ⟨hal-00844390⟩
289 Consultations
467 Téléchargements
