State-based representation of CCSL operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
The UML Profile for Modeling and Analysis of Real-Time and Embedded systems promises a general modeling framework to design and analyze systems. Lots of works have been published on the modeling capabilities offered by MARTE, much less on verification techniques supported. The Clock Constraint Specification Language (CCSL), first introduced as a companion language for MARTE, was devised to offer a formal support to conduct causal and temporal analyses on MARTE models. This work introduces formally a state-based semantics for CCSL operators.
rr-8334.pdf (719.41 Ko) Télécharger le fichier
hal-00846684 , version 1 (19-07-2013)
hal-00846684 , version 2 (21-07-2013)
hal-00846684 , version 3 (26-07-2013)
hal-00846684 , version 4 (12-09-2013)
  • HAL Id : hal-00846684 , version 4
Frédéric Mallet, Jean-Vivien Millo, Yuliia Romenska. State-based representation of CCSL operators. [Research Report] RR-8334, INRIA. 2013. ⟨hal-00846684v4⟩
334 Consultations
323 Téléchargements
