Universal Point Sets for Planar Graph Drawings with Circular Arcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We prove that there exists a set S of n points in the plane such that every n-vertex planar graph G admits a plane drawing in which every vertex of G is placed on a distinct point of S and every edge of G is drawn as a circular arc.
Hal.pdf (332.51 Ko) Télécharger le fichier
Format : Figure, Image
hal-00846953 , version 1 (22-07-2013)
  • HAL Id : hal-00846953 , version 1
Patrizio Angelini, David Eppstein, Fabrizio Frati, Michael Kaufmann, Sylvain Lazard, et al.. Universal Point Sets for Planar Graph Drawings with Circular Arcs. Canadian Conference on Computational Geometry, Aug 2013, Waterloo, Canada. pp.117-122. ⟨hal-00846953⟩
561 Consultations
247 Téléchargements
