Additive noise quenches delay-induced oscillations
Noise has significant impact on nonlinear phenomena. Here we demonstrate that, in opposition to previous assumptions, additive noise interfere with the linear stability of scalar nonlinear sys- tems when these are subject to time delay. We show this by performing a recently designed time- dependent delayed center manifold (DCM) reduction around an Hopf bifurcation in a model of nonlinear negative feedback. Using this, we show that noise intensity must be considered as a bifur- cation parameter and thus shifts the threshold at which emerge delay-induced rhythmic solutions.
Modélisation et simulation
