On a nonlocal, nonlinear Schrödinger equation occuring in Plasma Physics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
Thierry Colin
  • Fonction : Auteur
  • PersonId : 836679
  • IdRef : 069826188
In this work, our goal is to study the Cauchy problem for a nonlocal, nonlinear Schr ̈odinger equation occuring in Plasma Physics. We shall construct solutions in the energy space; we give some sufficient conditions on the initial data which ensure that the solutions are global and we show that in some cases, finite time blow up occurs. We prove the existence of standing waves, solution to these equations and provide some stability results.
8pages.pdf (192.02 Ko) Télécharger le fichier
hal-00848075 , version 1 (25-07-2013)
  • HAL Id : hal-00848075 , version 1
Thierry Colin. On a nonlocal, nonlinear Schrödinger equation occuring in Plasma Physics. Nonlinear evolution equations and dynamical systems, NEED's 92, 1992, Dubna, Russia. ⟨hal-00848075⟩
195 Consultations
222 Téléchargements
