On the Cauchy problem for dispersive equations with nonlinear terms involving high derivatives and with arbitrarily large initial data
The aim of this article is to study the Cauchy problem for general nonlinear dispersive equations involving derivatives in the nonlinearity. The use of some decay properties of the linear part allows us to address the case of arbitrarily large initial data.
