Haptic simulation of the liver with respiratory motion. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
During a standard procedure of liver biopsy, the motion due to respira- tion may be difficult to handle. The patient is often requested to hold his breath or to breathe shallowly. Ideally, this physiological behaviour should be taken into account in a virtual reality biopsy simulator. This paper presents a framework that accurately simulates respiratory motion, allowing for the fine tuning of relevant pa- rameters in order to produce a patient-specific breathing pattern that can then be in- corporated into a simulation with real-rime haptic interaction. This work has been done as part of the CRaIVE collaboration[1], which aims to build interventional radiology simulators.
VILLARD_P_2.pdf (249.98 Ko) Télécharger le fichier
Format : Figure, Image
hal-00849196 , version 1 (30-07-2013)
  • HAL Id : hal-00849196 , version 1
Pierre-Frederic Villard, Mathieu Jacob, Derek Gould, Fernando Bello. Haptic simulation of the liver with respiratory motion.. Proceeding of Medicine Meets Virtual Reality 17 (MMVR17), 2009, Long Beach, California, United States. pp.401-6. ⟨hal-00849196⟩
Collections
TDS-MACS
208 Consultations
163 Téléchargements
