Resolution of Non-Linear Problems In Realistic-Lung-Inflating Simulation with Finite Element Method. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Hadrontherapy treatment needs accurate tumour targeting, which is difficult for lung cancer due to breathing motions. We propose to quantify lung deformation and displacement by a simulation technique based on the geometrical and mechanical properties of organs. Thereby, we model lung behaviour by a 3D dynamic deformable model derived from continuous mechanics, computed with finite elements method (FEM).
hcpbm2005.pdf (70.29 Ko) Télécharger le fichier
Format : Figure, Image
hal-00849205 , version 1 (30-07-2013)
  • HAL Id : hal-00849205 , version 1
Pierre-Frédéric Villard, Vincent Baudet, Michaël Beuve, Behzad Shariat, Fabrice Jaillet. Resolution of Non-Linear Problems In Realistic-Lung-Inflating Simulation with Finite Element Method.. 10th workshop on Heavy Charged Particles in Biology and Medicine. Oropa (Italy), 2005, Oropa, Italy. pp.184--187. ⟨hal-00849205⟩
248 Consultations
124 Téléchargements
