Towards Accurate Tumour Tracking in Lungs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Motivated by radiotherapy and hadrontherapy improvement, we consider in a first step the potential of simple elastic mechanical modelling of the lung. We propose to simulate his deformation and motion during respiration towards tracking tumours. We present two approaches, based on finite-elements method and mass-spring system. For this, we suggest a personalised model based on the measurement of patient's physical and geometrical data.
London03.pdf (484.45 Ko) Télécharger le fichier
Format : Figure, Image
hal-00849207 , version 1 (30-07-2013)
  • HAL Id : hal-00849207 , version 1
Vincent Baudet, Pierre-Frédéric Villard, Fabrice Jaillet, Michaël Beuve, Behzad Shariat. Towards Accurate Tumour Tracking in Lungs. Information Visualisation, 2003, London, United Kingdom. pp.338--343. ⟨hal-00849207⟩
268 Consultations
241 Téléchargements
