About identification of defects in an elastic-plastic medium from boundary measurements in the antiplane case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Analysis Année : 2011
This article is devoted to a new method to find defects in some elasticplastic structure in the antiplane case from overdetermined data on a subpart of its boundary. This iterative method merges the method of quasireversibility and a simple level set technique. The foundations of the method are justified from a theoretical point of view and its efficiency is shown with the help of numerical experiments. © 2011 Taylor & Francis.
Fichier non déposé
hal-00849572 , version 1 (30-08-2013)
Laurent Bourgeois, Jérémi Dardé. About identification of defects in an elastic-plastic medium from boundary measurements in the antiplane case. Applicable Analysis, 2011, 90 (10), pp.1481-1497. ⟨10.1080/00036811.2010.549481⟩. ⟨hal-00849572⟩
155 Consultations
0 Téléchargements
