A Self-Triggered Control Based on Convex Embeddings for Perturbed LTI Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we present a novel self-triggered control which aims at decreasing the number of sampling instants for the state feedback control of perturbed linear time invariant systems. The approach is based on convex embeddings that allow for designing a state-dependent sampling function guaranteeing the system's exponential stability for a desired decay-rate and norm-bounded perturbations. One of the main contributions of this paper is an LMI based algorithm that optimizes the choice of the Lyapunov function so as to enlarge the lower-bound of the sampling function while taking into account both the perturbations and the decay-rate. The advantages of the approach are illustrated with a numerical example from the literature.
NOLCOS 2013 - Final version.pdf (183.11 Ko) Télécharger le fichier
hal-00849840 , version 1 (07-09-2015)
Christophe Fiter, Laurentiu Hetel, Wilfrid Perruquetti, Jean-Pierre Richard. A Self-Triggered Control Based on Convex Embeddings for Perturbed LTI Systems. 9th IFAC Symposium on Nonlinear Control Systems, Sep 2013, Toulouse, France. pp.335-340, ⟨10.3182/20130904-3-FR-2041.00176⟩. ⟨hal-00849840⟩
215 Consultations
127 Téléchargements
