Uniformly accurate numerical schemes for highly oscillatory Klein-Gordon and nonlinear Schrödinger equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2015
This work is devoted to the numerical simulation of nonlinear Schrödinger and Klein-Gordon equations. We present a general strategy to construct numerical schemes which are uniformly accurate with respect to the oscillation frequency. This is a stronger feature than the usual so called ''Asymptotic preserving" property, the last being also satisfied by our scheme in the highly oscillatory limit. Our strategy enables to simulate the oscillatory problem without using any mesh or time step refinement, and the orders of our schemes are preserved uniformly in all regimes. In other words, since our numerical method is not based on the derivation and the simulation of asymptotic models, it works in the regime where the solution does not oscillate rapidly, in the highly oscillatory limit regime, and in the intermediate regime with the same order of accuracy. In the same spirit as in \cite{clm}, the method is based on two main ingredients. First, we embed our problem in a suitable ''two-scale" reformulation with the introduction of an additional variable. Then a link is made with classical strategies based on Chapman-Enskog expansions in kinetic theory despite the dispersive context of the targeted equations, allowing to separate the fast time scale from the slow one. Uniformly accurate (UA) schemes are eventually derived from this new formulation and their properties and performances are assessed both theoretically and numerically.
cclm.pdf (1.93 Mo) Télécharger le fichier
hal-00850092 , version 1 (02-08-2013)
Philippe Chartier, Nicolas Crouseilles, Mohammed Lemou, Florian Méhats. Uniformly accurate numerical schemes for highly oscillatory Klein-Gordon and nonlinear Schrödinger equations. Numerische Mathematik, 2015, 129 (2), pp.211-250. ⟨10.1007/s00211-014-0638-9⟩. ⟨hal-00850092⟩
349 Consultations
157 Téléchargements
