Optimal 3D reconstruction of plants canopy from terrestrial laser scanner data by fusion of the 3D point information and the intensity value - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We develop an algorithm to digitize in situ canopy and to tag automatically each of its leaves. This algorithm fuses the distance information and the intensity values of a terrestrial LiDAR scanner.
BalduzziBoudonGodin2013.pdf (273.53 Ko) Télécharger le fichier
Format : Figure, Image
hal-00850793 , version 1 (08-08-2013)
  • HAL Id : hal-00850793 , version 1
Mathilde Balduzzi, Frédéric Boudon, Christophe Godin. Optimal 3D reconstruction of plants canopy from terrestrial laser scanner data by fusion of the 3D point information and the intensity value. 7th International Conference on Functional-Structural Plant Models, Jun 2013, Saariselkä, Finland. pp.58-60. ⟨hal-00850793⟩
308 Consultations
1123 Téléchargements
