Using Concrete Scales: A Practical Framework for Effective Visual Depiction of Complex Measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2013
Fanny Chevalier
dgp
Romain Vuillemot
Guia Gali
  • Fonction : Auteur
  • PersonId : 944503
From financial statistics to nutritional values, we are frequently exposed to quantitative information expressed in measures of either extreme magnitudes or unfamiliar units, or both. A common practice used to comprehend such complex measures is to relate, re-express, and compare them through visual depictions using magnitudes and units that are easier to grasp. Through this practice, we create a new graphic composition that we refer to as a concrete scale. To the best of our knowledge, there are no design guidelines that exist for concrete scales despite their common use in communication, educational, and decision-making settings. We attempt to fill this void by introducing a novel framework that would serve as a practical guide for their analysis and design. Informed by a thorough analysis of graphic compositions involving complex measures and an extensive literature review of scale cognition mechanisms, our framework outlines the design space of various measure relations--specifically relations involving the re-expression of complex measures to more familiar concepts--and their visual representations as graphic compositions.
Informatique
scalecomparison.pdf (8.4 Mo) Télécharger le fichier
Format : Figure, Image
hal-00851733 , version 1 (08-01-2014)
hal-00851733 , version 2 (08-01-2014)
Fanny Chevalier, Romain Vuillemot, Guia Gali. Using Concrete Scales: A Practical Framework for Effective Visual Depiction of Complex Measures. IEEE Transactions on Visualization and Computer Graphics, 2013, 19 (12), pp.2426-2435. ⟨10.1109/TVCG.2013.210⟩. ⟨hal-00851733v2⟩
629 Consultations
1093 Téléchargements
