The effect of Time Scales in Photosynthesis on microalgae Productivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioprocess and Biosystems Engineering Année : 2014
Microalgae are often seen as a potential biofuel producer. In order to predict achievable productivities in the so called raceway culturing system, the dy- namics of photosynthesis has to be taken into account. In particular, the dynami- cal effect of inhibition by an excess of light (photoinhibition) must be represented. We propose a model considering both photosynthesis and growth dynamics. This model involves three different time scales. We study the response of this model to uctuating light with different frequencies by slow/fast approximations. Therefore, we identify three different regimes for which a simplified expression for the model can be derived. These expressions give a hint on productivity improvement which can be expected by stimulating photosynthesis with a faster hydrodynamics.
2013_Hartmann_BBE.pdf (1.28 Mo) Télécharger le fichier
hal-00852255 , version 1 (20-08-2013)
Philipp Hartmann, Quentin Béchet, Olivier Bernard. The effect of Time Scales in Photosynthesis on microalgae Productivity. Bioprocess and Biosystems Engineering, 2014, 37 (1), pp.17-25. ⟨10.1007/s00449-013-1031-2⟩. ⟨hal-00852255⟩
263 Consultations
434 Téléchargements
