Extracting brain regions from rest fMRI with Total-Variation constrained dictionary learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Spontaneous brain activity reveals mechanisms of brain function and dysfunction. Its population-level statistical analysis based on functional images often relies on the de nition of brain regions that must summarize e ciently the covariance structure between the multiple brain networks. In this paper, we extend a network-discovery approach, namely dictionary learning, to readily extract brain regions. To do so, we intro duce a new tool drawing from clustering and linear decomposition methods by carefully crafting a penalty. Our approach automatically extracts regions from rest fMRI that better explain the data and are more stable across subjects than reference decomposition or clustering methods.
paper598.pdf (2.11 Mo) Télécharger le fichier
hal-00853242 , version 1 (11-09-2014)
  • HAL Id : hal-00853242 , version 1
Alexandre Abraham, Elvis Dohmatob, Bertrand Thirion, Dimitris Samaras, Gaël Varoquaux. Extracting brain regions from rest fMRI with Total-Variation constrained dictionary learning. MICCAI - 16th International Conference on Medical Image Computing and Computer Assisted Intervention - 2013, Sep 2013, Nagoya, Japan. ⟨hal-00853242⟩
386 Consultations
763 Téléchargements
