Non-oriented MLS Gradient Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2013
We introduce a new approach for defining continuous non-oriented gradient fields from discrete inputs, a fundamental stage for a variety of computer graphics applications such as surface or curve reconstruction, and image stylization. Our approach builds on a moving least square formalism that computes higher-order local approximations of non-oriented input gradients. In particular, we show that our novel isotropic linear approximation outperforms its lower-order alternative: surface or image structures are much better preserved, and instabilities are significantly reduced. Thanks to its ease of implementation (on both CPU and GPU) and small performance overhead, we believe our approach will find a widespread use in graphics applications, as demonstrated by the variety of our results.
MLS_grad_2013.pdf (19.99 Mo) Télécharger le fichier
MLS_grad_2013.mp4 (87.9 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00857265 , version 1 (03-09-2013)
Jiazhou Chen, Gael Guennebaud, Pascal Barla, Xavier Granier. Non-oriented MLS Gradient Fields. Computer Graphics Forum, 2013, 32 (8), pp.98-109. ⟨10.1111/cgf.12164⟩. ⟨hal-00857265⟩
1431 Consultations
1307 Téléchargements
