Sensitivity analysis and characterization of the uncertain input data for the EXPERT vehicle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
The paper investigates a new methodology to rebuild freestream conditions for the trajectory of a re-entry vehicle from measurements of stagnation-point pressure and heat flux. Uncertainties due to measurements and model parameters are taken into account and a Bayesian setting is used to solve the associated stochastic inverse problem. A sensitivity analysis based on a stochastic spectral framework is first investigated to study the impact of uncertain input data on stagnation-point measurements. An original backward uncertainty propagation method is then proposed, for which only the uncertainties that have the most impact are retained.
RR-8360.pdf (1.02 Mo) Télécharger le fichier
hal-00859809 , version 1 (09-09-2013)
  • HAL Id : hal-00859809 , version 1
Julie Tryoen, Pietro Marco Congedo, Remi Abgrall, Thierry E. Magin, Nadège Villedieu. Sensitivity analysis and characterization of the uncertain input data for the EXPERT vehicle. [Research Report] RR-8360, INRIA. 2013. ⟨hal-00859809⟩
176 Consultations
126 Téléchargements
