An Experimental Comparison between ATNoSFERES and ACS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
After two papers comparing ATNoSFERES with XCSM, a Learning Classifier System with internal states, this paper is devoted to a comparison between ATNoSFERES and ACS (an Anticipatory Learning Classifier System). As previously, we focus on the way perceptual aliazing problems encountered in non-Markov environments are solved with both kinds of systems. We shortly present ATNoSFERES, a framework based on an indirect encoding Genetic Algorithm which builds finite-state automata controllers, and we compare it with ACS through two benchmark experiments. The comparison shows that the difference in performance between both system depends on the environment. This raises a discussion of the adequacy of both adaptive mechanisms to particular subclasses of non-Markov problems. Furthermore, since ACS converges much faster than ATNoSFERES, we discuss the need to introduce learning capabilities in our model. As a conclusion, we advocate for the need of more experimental comparisons between different systems in the Learning Classifier System community.
2003-IWLCS.pdf (375.71 Ko) Télécharger le fichier
hal-00860490 , version 1 (02-04-2019)
  • HAL Id : hal-00860490 , version 1
Samuel Landau, Olivier Sigaud, Sébastien Picault, Pierre Gérard. An Experimental Comparison between ATNoSFERES and ACS. 6th International Workshop on Learning Classifier Systems (IWLCS'2003), 2003, Chicago, United States. pp.144-160. ⟨hal-00860490⟩
200 Consultations
72 Téléchargements
