The role of intrinsic motivations in learning sensorimotor vocal mappings: a developmental robotics study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Learning complex mappings between various modalities (typically articulatory, somato­sensory and auditory) is a central issue in computationally modeling speech acquisition. These mappings are generally non­linear and redundant, involving high dimensional sensorimotor spaces. Classical approaches consider two separate phases: a relatively pre-determined exploration phase analogous to infant babbling followed by an exploitation phase involving higher level communicative motivations. In this paper, we consider the problem as a developmental robotics one, in which an agent actively learns sensorimotor mappings of an articulatory vocal model. More specifically, we show how intrinsic motivations can allow the emergence of efficient exploration strategies, driving the way a learning agent will interact with its environment to collect an adequate learning set.
IS13full_paper.pdf (272.11 Ko) Télécharger le fichier
hal-00860655 , version 1 (11-09-2013)
  • HAL Id : hal-00860655 , version 1
Clément Moulin-Frier, Pierre-Yves Oudeyer. The role of intrinsic motivations in learning sensorimotor vocal mappings: a developmental robotics study. Interspeech, ISCA, Aug 2013, Lyon, France. ⟨hal-00860655⟩
347 Consultations
270 Téléchargements
