A tensor motion descriptor based on histograms of gradients and optical flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Letters Année : 2014
This paper presents a new tensor motion descriptor only using optical flow and HOG3D information: no interest points are extracted and it is not based on a visual dictionary. We propose a new aggregation technique based on tensors. This is a double aggregation of tensor descriptors. The first one represents motion by using polynomial coefficients which approximates the optical flow. The other represents the accumulated data of all histograms of gradients of the video. The descriptor is evaluated by a classification of KTH, UCF11 and Hollywood2 datasets, using a SVM classifier. Our method reaches 93.2% of recognition rate with KTH, comparable to the best local ap- proaches. For the UCF11 and Hollywood2 datasets, our recognition achieves fairly competitive results compared to local and learning based approaches. Keywords: Global motion descriptor, optical flow, histogram of gradients, action recognition
mota13prl.pdf (259.04 Ko) Télécharger le fichier
hal-00861395 , version 1 (12-09-2013)
Virginia Fernandes Mota, Eder de Almeida Perez, Silva Maciel Luiz Maurílio Da, Marcelo Bernardes Vieira, Philippe-Henri Gosselin. A tensor motion descriptor based on histograms of gradients and optical flow. Pattern Recognition Letters, 2014, 39, pp.85-91. ⟨10.1016/j.patrec.2013.08.008⟩. ⟨hal-00861395⟩
705 Consultations
520 Téléchargements
