Transforming EVENT B Models into Verified C# Implementations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The refinement-based approach to developing software is based on the correct-by-construction paradigm where software systems are constructed via the step-by-step refinement of an initial high- level specification into a final concrete specification. Proof obligations, generated during this process are discharged to ensure the consistency between refinement levels and hence the system's overall correctness. Here, we are concerned with the refinement of specifications using the EVENT B modelling lan- guage and its associated toolset, the RODIN platform. In particular, we focus on the final steps of the process where the final concrete specification is transformed into an executable algorithm. The transformations involved are (a) the transformation from an EVENT B specification into a concrete recursive algorithm and (b) the transformation from the recursive algorithm into its equivalent itera- tive version. We prove both transformations correct and verify the correctness of the final code in a static program verification environment for C# programs, namely the Spec# programming system.
Fichier non déposé
hal-00862050 , version 1 (15-09-2013)
  • HAL Id : hal-00862050 , version 1
Dominique Méry, Monahan Rosemary. Transforming EVENT B Models into Verified C# Implementations. VPT 2013 - First International Workshop on Verification and Program Transformation, Alexei Lisitsa and Andrei Nemytykh, Jul 2013, Saint Petersburg, Russia. pp.57-73. ⟨hal-00862050⟩
195 Consultations
0 Téléchargements
