Towards Automatic Acne Detection Using a MRF Model with Chromophore Descriptors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a new acne detection approach using a Markov random field (MRF) model and chromophore descriptors extracted by bilateral decomposition. Compared to most existing acne segmentation methods, the proposed algorithm enables to cope with large-dynamic-range intensity usually existing in conventional RGB acne images captured under uncontrolled environment. Algorithm performance has been tested on acne images of human face from a free public database. Experimental results show that acne segmentation derived from this new approach highly agrees to human visual inspection. Moreover, inflammatory response and hyperpigmentation scar can be well discriminated. It is expected that a computer-assisted diagnostic system for acne severity evaluation will be constructed as a consequence of the present work.
1569743671_2_.pdf (373.64 Ko) Télécharger le fichier
hal-00863046 , version 1 (18-09-2013)
  • HAL Id : hal-00863046 , version 1
Zhao Liu, Josiane Zerubia. Towards Automatic Acne Detection Using a MRF Model with Chromophore Descriptors. European Signal Processing Conference (EUSIPCO), Sep 2013, Marrakech, Morocco. ⟨hal-00863046⟩
237 Consultations
1709 Téléchargements
