Discrete Control of Computing Systems Administration: a Programming Language supported Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of using Discrete Controller Synthesis for the administration of Computing Systems, following an approach supported by a programming language. We present a mixed imperative/declarative programming language, where declarative contracts are enforced upon imperatively described behaviors. Its compilation is based on the notion of supervisory control of discrete event systems. It targets the programming of closed-loop reconfiguration controllers in computing systems. We apply our method to the problem of coordinating several administration loops in a data center (number of servers, repair, and local processor frequencies) : we formulate it as an invariance controller synthesis problem.
ECC2013.pdf (248.61 Ko) Télécharger le fichier
hal-00863276 , version 1 (18-09-2013)
  • HAL Id : hal-00863276 , version 1
Gwenaël Delaval, Noel de Palma, Soguy Mak-Karé Gueye, Hervé Marchand, Eric Rutten. Discrete Control of Computing Systems Administration: a Programming Language supported Approach. European Control Conference, Jul 2013, Zurich, Switzerland. pp.117-124. ⟨hal-00863276⟩
557 Consultations
175 Téléchargements
