Splat-based Surface Reconstruction from Defect-Laden Point Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2013
Ricard Campos
  • Fonction : Auteur
  • PersonId : 945602
Pierre Alliez
Mariette Yvinec
We introduce a method for surface reconstruction from point sets that is able to cope with noise and outliers. First, a splat-based representation is computed from the point set. A robust local 3D RANSAC-based procedure is used to filter the point set for outliers, then a local jet surface -- a low-degree surface approximation -- is fitted to the inliers. Second, we extract the reconstructed surface in the form of a surface triangle mesh through Delaunay refinement. The Delaunay refinement meshing approach requires computing intersections between line segment queries and the surface to be meshed. In the present case, intersection queries are solved from the set of splats through a 1D RANSAC procedure.
splat.pdf (9.79 Mo) Télécharger le fichier
Format : Figure, Image
hal-00863316 , version 1 (18-09-2013)
Ricard Campos, Rafael Garcia, Pierre Alliez, Mariette Yvinec. Splat-based Surface Reconstruction from Defect-Laden Point Sets. Graphical Models, 2013, 75 (6), pp.346-361. ⟨10.1016/j.gmod.2013.08.001⟩. ⟨hal-00863316⟩
343 Consultations
3062 Téléchargements
