Robust diameter-based thickness estimation of 3D objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2013
We propose a robust thickness estimation approach for 3D objects based on the Shape Diameter Function (SDF). Our method first applies a modified strategy to estimate the local diameter with increased accuracy. We then compute a scale-dependent robust thickness estimate from a point cloud, constructed using this local diameter estimation and a variant of a robust distance function. The robustness of our method is benchmarked against several operations such as remeshing, geometric noise and artifacts common in triangle soups. The experimental results show a more stable local thickness estimation than the original SDF, and consistent segmentation results on defect-laden inputs.
thickness.pdf (8.57 Mo) Télécharger le fichier
Format : Figure, Image
hal-00863689 , version 1 (19-09-2013)
Rolland-Nevière Xavier, Gwenaël Doërr, Pierre Alliez. Robust diameter-based thickness estimation of 3D objects. Graphical Models, 2013, 75 (6), pp.279-296. ⟨10.1016/j.gmod.2013.06.001⟩. ⟨hal-00863689⟩
Collections
INRIA INRIA2
260 Consultations
4196 Téléchargements
