Relocation of Mobile Wireless Sensors in the Presence of Obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In many applications (e.g military, environment monitoring), wireless sensors are randomly deployed in a given area. Unfortunately, this deployment is not efficient enough to ensure area coverage and network connectivity. Algorithms based on Virtual Forces are used to improve the random initial deployment. In this paper, we want to ensure coverage and network connectivity in a given area containing obstacles. We enhance the Distributed Virtual Forces Algorithm (DVFA) to cope with obstacles. Obstacles are characterized by prohibiting both the physical presence of sensors and the wireless communication. Performance evaluation shows that DVFA provides an efficient deployment even if obstacles exist in the considered area.
ICT_2013.pdf (519.22 Ko) Télécharger le fichier
hal-00864258 , version 1 (20-09-2013)
  • HAL Id : hal-00864258 , version 1
Saoucene Mahfoudh, Ines Khoufi, Pascale Minet, Anis Laouiti. Relocation of Mobile Wireless Sensors in the Presence of Obstacles. ICT 2013 - 20th International Conference on Telecommunications, May 2013, Casablanca, Morocco. pp.1-5. ⟨hal-00864258⟩
305 Consultations
331 Téléchargements
