Faster Gaussian Lattice Sampling Using Lazy Floating-Point Arithmetic
Many lattice cryptographic primitives require an efficient algorithm to sample lattice points according to some Gaussian distribution. All algorithms known for this task require long-integer arithmetic at some point, which may be problematic in practice. We study how much lattice sampling can be sped up using floating-point arithmetic. First, we show that a direct floating-point implementation of these algorithms does not give any asymptotic speedup: the floating-point precision needs to be greater than the security parameter, leading to an overall complexity $\softO(n^3)$ where $n$ is the lattice dimension. However, we introduce a laziness technique that can significantly speed up these algorithms. Namely, in certain cases such as NTRUsign lattices, laziness can decrease the complexity to $\softO(n^2)$ or even $\softO(n)$. Furthermore, our analysis is practical: for typical parameters, most of the floating-point operations only require the double-precision IEEE standard.
