Faster Algorithms for Approximate Common Divisors: Breaking Fully-Homomorphic-Encryption Challenges over the Integers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
At EUROCRYPT '10, van Dijk et al. presented simple fully- homomorphic encryption (FHE) schemes based on the hardness of approximate integer common divisors problems, which were introduced in 2001 by Howgrave-Graham. There are two versions for these problems: the partial version (PACD) and the general version (GACD). The seemingly easier problem PACD was recently used by Coron et al. at CRYPTO '11 to build a more efficient variant of the FHE scheme by van Dijk et al.. We present a new PACD algorithm whose running time is essentially the "square root" of that of exhaustive search, which was the best attack in practice. This allows us to experimentally break the FHE challenges proposed by Coron et al. Our PACD algorithm directly gives rise to a new GACD algorithm, which is exponentially faster than exhaustive search. Interestingly, our main technique can also be applied to other settings, such as noisy factoring and attacking low-exponent RSA.
ChenNguyen.pdf (343.49 Ko) Télécharger le fichier
hal-00864374 , version 1 (21-09-2013)
Yuanmi Chen, Phong Q. Nguyen. Faster Algorithms for Approximate Common Divisors: Breaking Fully-Homomorphic-Encryption Challenges over the Integers. EUROCRYPT 2012, IACR, Apr 2012, Cambridge, United Kingdom. pp.502-519, ⟨10.1007/978-3-642-29011-4_30⟩. ⟨hal-00864374⟩
681 Consultations
684 Téléchargements
