Unsupervised marked point process model for boat extraction in harbors from high resolution optical remotely sensed images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marked point process models have been successfully used in image analysis for feature extraction purposes in high resolution remotely sensed images. The model is usually based on two types of energy terms: a data term, which reflects the configuration's fidelity with respect to the input image, and a prior term, which reflects some knowledge about the objects to be extracted. In this paper, we deal with the problem of elliptical shape extraction. We propose new energy terms for the extraction of boats in harbors, which is a particularly difficult problem and we show results on high resolution optical images.
ICIP_13.pdf (950.05 Ko) Télécharger le fichier
hal-00867585 , version 1 (30-09-2013)
  • HAL Id : hal-00867585 , version 1
Paula Craciun, Josiane Zerubia. Unsupervised marked point process model for boat extraction in harbors from high resolution optical remotely sensed images. IEEE ICIP - International Conference on Image Processing, Sep 2013, Melbourne, Australia. ⟨hal-00867585⟩
Collections
INRIA INRIA2
170 Consultations
277 Téléchargements
