Propagation Engine Prototyping with a Domain Specific Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Constraints Année : 2014
Constraint propagation is at the heart of constraint solvers. Two main trends co-exist for its implementation: variable-oriented propagation engines and constraint-oriented propagation engines. Those two approaches ensure the same level of local consistency but their efficiency (computation time) can be quite different depending on the instance solved. However, it is usually accepted that there is no best approach in general, and modern constraint solvers implement only one. In this paper, we would like to go a step further providing a solver independent language at the modeling stage to enable the design of propagation engines. We validate our proposal with a reference implementation based on the Choco solver and the MiniZinc constraint modeling language.
cons2013_propeng.pdf (378.85 Ko) Télécharger le fichier
hal-00867604 , version 1 (30-09-2013)
Charles Prud'Homme, Xavier Lorca, Rémi Douence, Narendra Jussien. Propagation Engine Prototyping with a Domain Specific Language. Constraints, 2014, 19 (1), pp.57-76. ⟨10.1007/s10601-013-9151-5⟩. ⟨hal-00867604⟩
264 Consultations
340 Téléchargements
