Geometric and numerical methods in the contrast imaging problem in nuclear magnetic resonance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Applicandae Mathematicae Année : 2015
In this article, the contrast imaging problem in nuclear magnetic resonance is modeled as a Mayer problem in optimal control. The optimal solution can be found as an extremal, solution of the Maximum Principle and analyzed with the techniques of geometric control. This leads to a numerical investigation based on so-called indirect methods using the HamPath software. The results are then compared with a direct method implemented within the Bocop toolbox. Finally lmi techniques are used to estimate a global optimum.
art.pdf (639.69 Ko) Télécharger le fichier
hal-00867753 , version 1 (30-09-2013)
hal-00867753 , version 2 (19-12-2014)
Bernard Bonnard, Mathieu Claeys, Olivier Cots, Pierre Martinon. Geometric and numerical methods in the contrast imaging problem in nuclear magnetic resonance. Acta Applicandae Mathematicae, 2015, 135 (1), pp.5-45. ⟨10.1007/s10440-014-9947-3⟩. ⟨hal-00867753v2⟩
781 Consultations
695 Téléchargements
