Extracting Business Rules from COBOL: A Model-Based Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Organizations rely on the logic embedded in their Information Systems for their daily operations. This logic implements the business rules in place in the organization, which must be continuously adapted in response to market changes. Unfortunately, this evolution implies understanding and evolving also the underlying software components enforcing those rules. This is challenging because, first, the code implementing the rules is scattered throughout the whole system and, second, most of the time documentation is poor and out-of-date. This is specially true for older systems that have been maintained and evolved for several years (even decades). In those systems, it is not even clear which business rules are enforced nor whether rules are still consistent with the current organizational policies. In this sense, the goal of this paper is to facilitate the comprehension of legacy systems (in particular COBOL-based ones) by providing a model driven reverse engineering framework able to extract and visualize the business logic embedded in them.
paper-cameraready.pdf (373.22 Ko) Télécharger le fichier
hal-00869235 , version 1 (02-10-2013)
  • HAL Id : hal-00869235 , version 1
Valerio Cosentino, Jordi Cabot, Patrick Albert, Philippe Bauquel, Jacques Perronnet. Extracting Business Rules from COBOL: A Model-Based Framework. Working Conference on Reverse Engineering, Oct 2013, Koblenz, Germany. ⟨hal-00869235⟩
414 Consultations
1132 Téléchargements
