Extracting Business Rules from COBOL: A Model-Based Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a Business Rule Extraction tool for COBOL systems. Starting from a COBOL program, we derive a model-based representation of the source code and we provide a set of model transformations to identify and visualize the embedded business rules. In particular, the tool facilitates the definition of an application vocabulary and the identification of relevant business variables. In addition, such variables are used as starting point to slice the code in order to identify business rules, that are finally represented by means of textual and graphical artifacts. The tool has been developed as an Eclipse plug-in in collaboration with IBM France.
paper_new_cameraready.pdf (80.96 Ko) Télécharger le fichier
hal-00869236 , version 1 (02-10-2013)
  • HAL Id : hal-00869236 , version 1
Valerio Cosentino, Jordi Cabot, Patrick Albert, Philippe Bauquel, Jacques Perronnet. Extracting Business Rules from COBOL: A Model-Based Tool. Working Conference on Reverse Engineering, Oct 2013, Koblenz, Germany. ⟨hal-00869236⟩
337 Consultations
1624 Téléchargements
