A Dependable Slepian-Wolf Coding Based Clustering Algorithm for Data Aggregation in Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers the Slepian-Wolf coding based data aggregation problem and the corresponding dependable clustering problem in wireless sensor networks (WSNs). A dependable Slepian-Wolf coding based clustering (DSWC) algorithm is proposed to provide dependable clustering against cluster-head failures. The proposed D-SWC algorithm attempts to elect a primary cluster head and a backup cluster head for each cluster member during clustering so that once a failure occurs to the primary cluster head the cluster members within the failed cluster can promptly switchover to the backup cluster head and thus recover the connectivity of the failed cluster to the data sink without waiting for the next-round clustering to be performed. Simulation results show that the DSWC algorithm can effectively increase the amount of data transmitted to the data sink as compared with an existing nondependable clustering algorithm for Slepian-Wolf coding based data aggregation in WSNs.
1569795739.pdf (218.8 Ko) Télécharger le fichier
hal-00869426 , version 1 (02-12-2013)
  • HAL Id : hal-00869426 , version 1
Qihang Shu, Qiang Hu, Jun Zheng, Nathalie Mitton. A Dependable Slepian-Wolf Coding Based Clustering Algorithm for Data Aggregation in Wireless Sensor Networks. International Conference on Wireless Communications and Signal Processing (WCSP), Oct 2013, Hangzhou, China. ⟨hal-00869426⟩
Collections
INRIA INRIA2
112 Consultations
188 Téléchargements
